Hello,
First of all I'm sorry, I'm from Turkei and I know only English.
I'll buy a used XF 650 Freewind. 2001 model and 20.000 km. You know its cheaper than BMW F650.
I need some information about XF 650 and its parts. I couldn't find the orginal engine guard in Turkey and I need orginal engine guard photos to make it myself.
And i need the parts brand; new air filter, oil name oil filter, tires and chain informations.
Thanks again...
Can Cetin
Hi! I need your help about XF 650 parts
hi !
So the dirtguard on the engine is missing ?
Or do you mean the protection Systems you can buy as an add on ?
They are built byHepco&Becker as an example - but I don't know if you can build them by yourself to grant good protection.....
The single parts don't have any special brand names.You can use everything that fits from any company......
As for the Engine Oil - you can use 10W40 either from Castrol,Aral or any other company
Chain comes from D.I.D
All your stuff for the brakes comes e.g. from LUCAS
Oil Filter CHAMPION
etc,etc,etc.....
btw. the XF isn't only cheaper than the BMW - it's the better bike
Oil Filter CHAMPION
etc,etc,etc.....
www.schwampf.at
-Blödsinn reden...ungestraft-
www.schwampf.at
hepco&becker is about 120 Euros if you order at www.louis.de - i think they ship to turkey as well - maybe you found the complte set including the rear parts.
It's the same with Spark Plugs same - use the ones that fit.
I use SPLITFIRE Racinc V3 Platin (TP430B) which are 15 Euro /pc.
Or you can use NGK.....
www.schwampf.at
www.schwampf.at
