Rear shock absorber
Rear shock absorber
Please, I have a problem with very soft rear shock absorber, so I try to make adjustment at the valve on the gas tank, but without any succes. So I measure the gas pressure in the gas tank, and pressure gage show me 0 bar, there is no pressure in the tank. Probably I lost my gas in the tank. So please what is the corect pressure in the gas tank, and does anybody have the similar problem. Thank you.
- coca-cola1077
Hello,
sorry for my terrible english
so much as i know, you can not refill the tank. this is a unknown problem in this forum. i think you should buy a used shock-absorber. here is a link to a german used-part dealer:
http://www.bike-teile.de/index.php?seit ... lid=635487
i hope its a little help for you....
okay okay... i`ve read Aos`s answer.... you can refill, but the pressure..... i don`t know...
Zuletzt geändert von coca-cola1077 am 1. Aug 2009, 23:18, insgesamt 1-mal geändert.
Gruss Micha
That's not right, the tank can be refilled. A far as I know it is filled with nitrogen, but probably just air may be ok, too. But I don't know the correct pressure.
Mabey you can contact a repair shop that is specialized on suspensions or dirt-bikes in your country. I had my shock absorber repaired at http://www.pepe-tuning.de/, but thats in Germany and I don't know where you're from.
Regards,
Regards,
