Freewind stiffer rear suspension, swap?
SLOXF650
Beitrag von SLOXF650 »
Hi, does someone knows, or did swapped rear shock-suspension on xf650 with some other rear suspension from some other motorcycle?
Im asking because I have rear suspension on hard setting, but its still too soft. In front forks I have progressive springs and more thick fork oil and now the rear is way too soft its swinging in corners...
Kind regards
Re: Freewind stiffer rear suspension, swap?
some people here use the wilbers rear suspension.
SLOXF650
Hm wilbers is good, but its very expencive :) My friend swapped rear suspension on sv650s 03model with kawasaki z1000 oem rear suspension and the difference in driving was huge...
I thought if someone used oem suspension from some other bike, and replaced it with stock xf suspension...
-Frank-
Beitrag von -Frank- »
Another cheap way is to use the spring from a Honda 900 Hornet.
It is a harder spring and it works good.
I used it in my sons Freewind.
Try to get one in ebay.
In my Freewind, I used a wilbers from a Yamaha FZR 1000. But you need some selfmade bushings.
This is a very little longer and works perfect.
Its easier to find one from the FZR1000 than an used one for the Freewind. And it is complete adjustable.
SLOXF650
Thank you Frank for the informations. I think Ill look for some spring from hornet900 8)
Kind regards
